Battery drain with Beta 7
(Topic created: 10-18-2023 06:49 AM)
dshrest1
Cosmic Ray
Discussions
Is it just me or anyone else been noticing faster battery drain since the update on Beta 7?
Surfndez
Discussions
Actually, I've noticed the opposite on the GALAXY S23 ULTRA. It may be apps/hardware dependent. One UI 6 Beta 6 was draining my battery much faster. One of the first improvements I noticed. Let's wait and see.
Dez
Discussions
There's other threads that discuss this. I've added my info there, so yes it seems battery doesn't last as long as specs indicate.
GregCapps
Galaxy
Discussions
May be just my experience, but battery drain seems to be improved on Beta 7.
dshrest1
Cosmic Ray
Discussions
It sure has been the other way around for me. Battery life was ace with beta 6 but with beta 7 it seems to drain alot faster than anticipated!
ProfSoap
Cosmic Ray
Discussions
Opposite for me, it's better than beta 6......well let me rephrase, when on idle the phone doesn't drain as much battery as it used to in beta 6, but while using it I still feel the battery drain is an issue(still not as bad as beta 6 or the previous versions)
SammyS23
Galaxy
Discussions
They need to optimize efficiency
USBetaModerator2
Beta Moderator
Discussions
Hello,
Thank you for your feedback.
Please use the latest Samsung Members app to submit an error report (Samusng Members One UI Beta Program Beta Feedback Error Report.
- To provide UX or UI-related feedback, such as usability or feature suggestions, select "Beta community Suggestions" in the Beta recruitment notice of Samsung Members app.
We appreciate your contribution to the Beta Program.
Regards,
One UI Beta Team
l10
Halo
Discussions
Yes same with me. Lower battery life vs previous betas
