Battery problem
(Topic created: 12-29-2025 11:31 PM)
Sam1100
Cosmic Ray
Discussions
I am experiencing rapid battery depletion on my S25 Ultra. Could you please provide assistance with this issue?
Discussions
I would suggest putting all your apps that you are not using into "Deep Sleep". Downloaded apps and games can still run in the background causing battery drain. You can find this by swiping up on your home screen and going to the search bar at the bottom and typing in "Deep Sleeping Apps". When you get to the deep sleeping apps screen, tap on the "+" icon and select from the list, all the apps you don't use everyday and put those apps into a deep sleep. The apps will still function perfectly fine, they just won't run unless you specifically run them. They will go back to being in a deep sleep after you close out the app as well. Your battery should improve from there. I always put any apps I don't use into deep sleep. My lasts all day with heavy use.
Let me know if this helped in any way.
-CROW-
Supernova
Discussions
Already done all of that. Most of the apps are in deep sleep. No games at all.
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you very much for sharing your feedback.
To help us investigate further, please submit an Error Report through the Samsung Members app immediately after reproducing the problem:
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue.
We apologize for any inconvenience and appreciate your support in helping us improve the Beta experience.
Best regards,
One UI Beta Team
Shahpour
Galaxy
Discussions
Yes agree the fact is after beta 2 it's draining faster, I am all aware of steps mentioned above but before and after beta there is a big difference in battery usage
Meir76
Discussions
I have the same issue here with the battery drainage
Discussions
My battery is functioning just fine. I haven't plugged my phone in all day and it's just now at 59%. Maybe it's an isolated issue.
Zanthala
Halo
Discussions
I've had no issues in regards to this and I've used my phone pretty steadily all day. I would submit feedback.
TheBigE
Discussions
The phone seems to do well overall when idle (not being used), yet it drains pretty quickly once the screen is on. Still draining a bit more than I'd like compared to before beta install when screen is off. Definitely draining much more when screen is on.
SatwikR
Halo
Discussions
Please post your battery stats and app usage if possible. We'll see where the problem is.
