- Mute
โ06-28-2024 07:12 PM in
DiscussionsBeta 2 was supposed to fix battery drain isssues but I'm noticing heavy usage from Google Play Sevices and Google Assistant. Google Play services was over 31% today, I rebooted and cleared cache through recovery. The battery didn't even last 24 hours before hitting 20% remaining. Anyone else notice issues with Beta 2?
Solved! Go to Solution.
- Mute
โ06-29-2024 03:27 AM in
DiscussionsIn my case, battery life is really good after beta2. I did wipe cache partition, uninstall google assistant and update/reinstall it again.
- Mute
โ06-28-2024 10:49 PM in
DiscussionsConfirm
- Mute
- Mute
โ07-05-2024 07:59 AM in
DiscussionsThis seemed to make the battery better for me. I uninstalled Assistant and updated it after a cache clear.
- Mute
โ06-29-2024 09:34 AM in
DiscussionsI can confirm as well.
- Mute
โ06-30-2024 04:35 AM in
DiscussionsBattery drain is much worse on beta 2 for me as well.
- Mute
โ07-01-2024 09:45 AM in
DiscussionsHello @TimmyTwo2,
Thank you for your feedback.
Battery drainage issues are typically common throughout the Beta due to instability on software.
To better understand your issues in details, please report the errors back to us (Galaxy Wearable app > Contact us > Error Report) and we will analyze your logs in detail.
Regards,
One UI Beta Team
