Showing results forĀ
Search instead forĀ
Did you mean:Ā
Massive battery drain
(Topic created: 12-12-2021 08:38 AM)
userOtpBz4SvUL
Discussions
Battery has been draining ridiculously fast since the most recent update. No particular app shows high usage but I went from 100% to 45% in the course of 2 hours only listening to podcasts.
userxAZaVBf90D
Discussions
Same here
USBetaModerator
Beta Moderator
Discussions
Hello @userOtpBz4SvUL ,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung memberā€™s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
