Maximum battery saver mode not working properly
(Topic created: 08-13-2022 08:33 AM)
Bengalsfan86
Cosmic Ray
Discussions
So when I turn on max battery saving, it does not change the wallpaper to a dark wallpaper, nor does it disable the edge panel. I am trying it on the S22+. Not a super big problem since I don't use it very often but it's that the whole point of beta to test these things out.
Tom6068
Neutron Star
Discussions
Where is the setting for max battery saving?
Bengalsfan86
Cosmic Ray
Discussions
Is it the last toggle switch under the power saving menu. Screenshot_20220813_162025_Device care_1000000107_1660422025.jpg
Bengalsfan86
Cosmic Ray
Discussions
And when I was trying it I did have the switch turned on
USBetaModerator2
Beta Moderator
Discussions
Hello ,
Thank you for your feedback. If you haven’t already, Please update Samsung Members app to latest version from the Galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
