Rapid battery drain
(Topic created: 10-24-2021 10:22 AM)
Jeremykb352019
Discussions
The battery on my S21 Ultra seems to drain rapidly
user751201tmO21
Honored Contributor
Discussions
You've updated to beta3?
Folks were reporting battery issues prior to beta3, but after beta3 install, they're reporting improvements
I have a post in Tips:
Apps crashing on your beta - try this:
... give it a go and see if it helps
Batman96
Star
Discussions
My battery seems to be doing alot better in beta 3
JORGEMendoza
Discussions
Battery beta 3 way better than 2
beri
Comet
Discussions
Check your apps battery usage just to see if maybe there is a particular app causing the issue.
ramonq619
Discussions
Mine is worse than beta 2.
userr4ijxZyCts
Cosmic Ray
Discussions
Mine stopped after the first beta update.
USBetaModerator
Beta Moderator
Discussions
Hello @Jeremykb352019 ,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
