Showing results forΒ
Search instead forΒ
Did you mean:Β
Sound and adapt sound
(Topic created: 10-23-2021 01:21 PM)
iiDark
Comet
Discussions
As a previous user stated in a thread, everything sounded like it was in a tunnel for a bit until I changed the Dolby atmos sound to "music" or "voices" and this fixed that issue it seems.
While in there, I went back to sound quality and effects and when trying to go into "adapt sound" the entire settings app crashes. Unable to access "adapt sound" anymore.
I already submitted a bug report. Just posting for awareness.
MochaVex
Supernova
Discussions
I reported Adapt Sound crashing as well (even though I don't use it).
Leify
Comet
Discussions
So did I. They just replied it's incompatible and closed the report. Seems like it's not fruitful to report most things if they just get ignored.
USBetaModerator
Beta Moderator
Discussions
Hello @Leify ,
Incompatibility may be ok but crashing settings app is not.
Regards
One UI Beta Team
Leify
Comet
Discussions
Please instruct your report takers on some basic courtesy then and have them stop trying to tell us that it's user error when it clearly is not, as well as just ignoring and closing reported issues. They're not going to get useful information like that and it seems they're not forwarding reports either as I can personally see.
djav1985
Discussions
Same issue
USBetaModerator
Beta Moderator
Discussions
Hello @iiDark ,
Thank you very much for reporting the issue to us. We appreciate your contribution to the Beta community.
Regards
One UI Beta Team
