battery šŸ”‹ drain faster
(Topic created: 12-27-2024 08:57 AM)
Discussions
i don't know when I get new beta update it keeps draining battery life shorter
thankyouu
Black Hole
Discussions
I've noticed the same, but right now all we can do is wait šŸ™
Discussions
We can also submit bug reports via feedback that contain system logs - this is what I did for the Continuity Services battery drain issue in Beta 1 and it was fixed in Beta 2.
thankyouu
Black Hole
Discussions
Same here
Jwiz5
Discussions
Omg, you too. I thought I was the only one thinking that
Discussions
I keep reading a lot about the battery drain issue. To be honest, battery is lasting a few more minutes for me on One UI 7
zumaz
Cosmic Ray
Discussions
Look at my recent suggestions post. There are some apps that are draining battery on OneUI and they don't show up in the usage stats. Luckily I notice what apps I'm using and reinstalled them to see, the battery drain fixed itself. I'm projected to get 8-9 hrs of SOT on WiFi.
Edit: much better actuallyScreenshot_20241229_152542_Device care_1000029202_1735507542.png
userJAs42KPtET
Cosmic Ray
Discussions
Exit the beta program if your battery drains to fast, that's the quickest fix.
Discussions
i don't want go back to design and lost everything 😭
Ryanoutdoors
Galaxy
Discussions
My battery life has never been better so it's got to be something people have running in the background or something
