Battery charge indicator (the Pill) needs to be changed
(Topic created: 04-15-2025 12:25 PM)
Purplepeaker605
Cosmic Ray
Fold & Flip Phones
 Can somebody PLEASE fix the battery charge indicator? The new update has a terrible display for it..It is TINY SMALL AND SAYS HALF OF A NUMBER LIT UP??
Who would design such a thing? The battery condition is ThE most IMPORTANT status on the phone and I cannot imagine older people struggling to see this now..the whole top status bar is wayyy too SMALL!!! Please take a look at this..it was GREAT BEFORE..THANKS!
Robin621k
Honored Contributor
Fold & Flip Phones
Report it in the support section of the Members app through feedback.
The more people report it the more likely they will change it.
Robin621k
Honored Contributor
Fold & Flip Phones
It is the absolute worst thing they have added to Ui7.
Whoever designed the battery pill must be under 30 years old, and doesn't wear reading glasses.
I have a battery widget on my home screen and AOD just so I can see it clearly.
I hope with Goodlock they add just percentage with out the ridiculous pill.
Purplepeaker605
Cosmic Ray
Fold & Flip Phones
Terrible..and its HALF LIT! WHAT IS THAT??? ridiculous...anyway just hope they do something ..thanks ๐Ÿ˜ƒ
Robin621k
Honored Contributor
Fold & Flip Phones
Purplepeaker605
Cosmic Ray
Fold & Flip Phones
Ok thanks Robin! ๐Ÿ™
tcass35
Fold & Flip Phones
Agree
Fold & Flip Phones
Have you been into the developer settings by any chance? Also under accessibility settings zoom can mess it up and also in developer settings you can accidentally change your size and format of your screen if you're not careful so maybe reset developer settings if you've been in there and check your accessibility settings ๐Ÿ˜Š
AF
Purplepeaker605
Cosmic Ray
Fold & Flip Phones
Thanks..yes I had Samsung go in with the tutor app and check everything they fixed the widget size its great now thanks..I just think the dashboard up top looked big clear and easy before as I looked at my old note 6 and wow what a dfference! Whoever designed that was great..people want clear bigger and simple when it comes to that top bar its important stuff eg batt..wifi bars..can't imagine these older people for them
Fold & Flip Phones
Hey I understand completely That's awesome I'm glad you got it!! ๐Ÿ˜Ž
AF
Robin621k
Honored Contributor
Fold & Flip Phones
Did they fix just the pill in the status bar?
