Highlighted
Battery Problems of Galaxy Buds
JUMP TO SOLUTION
I've got two problems with my Galaxy Buds. The first one is that my right bud's battery drains like twice as fast as the left one. I don't use the touch pad very often. The other problem is that I guess the right bud is consuming battery when inside the case? I fully charge the case with buds in it all over the night and when I take them out of the case, most of the time the right one will not be full, like 60%, and the left one is full. If I put them back again, they can be fully charged to 100%. Everything was fine until one day I took them out of the case and the right one was somehow totally out of battery. I've tried reset the buds a few times and it didn't work. Any suggestions?
1 SOLUTION
Highlighted
Re: Battery Problems of Galaxy Buds
JUMP TO SOLUTION
@userOSzL5vwpJq, Thank you so much for giving that a try and confirming you are still having the issue.
Can you send us a private message with the below information here: http://bit.ly/2GH8URL
Serial Number:
Model Number:
31 REPLIES 31
Highlighted
JUMP TO SOLUTION
What is the software version of the buds?
Highlighted
JUMP TO SOLUTION
It's the latest version, which ends in SC4.
Highlighted
JUMP TO SOLUTION
Thank you! Please send a PM with the full model code serial number from the bottom of the cradle. http://bit.ly/2Kq3B5F
Highlighted
JUMP TO SOLUTION
Just sent, thank you.
Highlighted
JUMP TO SOLUTION
Any updates?
Highlighted
JUMP TO SOLUTION
Hi! I'm having the same issue here, My right earbud runs outta batter faster than the left one, I literally just bought my galaxy buds 2 days ago, Help?
Highlighted
JUMP TO SOLUTION
Hey guys, have you tried resetting the galaxy buds?
You can use this troubleshooting article to completely reset them: http://www.samsung.com/us/support/troubleshooting/TSG01111287/
Hope this finds you well
Highlighted
JUMP TO SOLUTION
I tried doing it but didn't fix my problem.
Highlighted
JUMP TO SOLUTION
Serial Number:
Model Number:
