Highlighted
Galaxy Buds Plus: overheating and draining battery
I've had my Galaxy Buds Plus for maybe three months now, but today my right ear bud started overheating and draining battery excessively. What should I do to solve this?
1 REPLY 1
Highlighted
Re: Galaxy Buds Plus: overheating and draining battery
Thank you for reaching out. Here are some things that may be causing the issue and some tips to correct the problem. https://www.samsung.com/us/support/answer/ANS00076952 If the earbud continues to overheat, please send a private message with the full model code and the serial number from the bottom of the cradle. http://bit.ly/2XERsky
