Highlighted
Galaxy Buds - Right earbud battery drain
JUMP TO SOLUTION
I've been using my Galaxy Buds for about 3 weeks now and this sudden problem started to occur. I could leave my buds at 100%, inside the charging case over the night, and when I wake up to check on them, my right earbud has completely drained while my left earbud is still at 100%. Same while using them, my right earbud seem to drain alot faster than my left one, the right one can suddenly be at 70 - 65% while my left earbud sits at 95%.
Is there a fix for this at all? Has anyone else encountered this problem?
1 SOLUTION
Highlighted
Re: Galaxy Buds - Right earbud battery drain
JUMP TO SOLUTION
Hey there guys!
Can you send me a private message with the below information here at this link: http://bit.ly/2GH8URL
Model code:
Serial Numer:
83 REPLIES 83
Highlighted
JUMP TO SOLUTION
I just bought the Galaxy Earbuds less than a week ago, first few days they were great.  Now, right earbud drains power way way faster than the left.  I workout at the gym for 120 minutes and the right earbud is down to 30% while the left earbud is at 80%.  When I put it in the base for recharging, it charges way slower than the left side.  This problem has been occuring for the last 4 days and I have owned them for 12 days.
The other issue I have with the earbuds, they stutter while playing music.  They will be fine for about 30 minutes then start to stutter every 8 to 10 minutes.  The earbuds feel good in my ears and stay when I put them in but if I am going to have issues with power drain being unequal and stuttering, what's the point of keeping them especially at the price you pay for them?
Highlighted
JUMP TO SOLUTION
Hey there guys!
Model code:
Serial Numer:
Highlighted
JUMP TO SOLUTION
@SamsungZell
Is there a solution to this issue?
I received my Galaxy Buds yesterday and have the same issue.  Upon unboxing, the right bud was completely drained.  Left bud was at 80%.
Right bud drains twice as fast durng use and charges at a much slower rate.
What's up with that?  Do I need to send them back for a refund?
Highlighted
JUMP TO SOLUTION
@GPMonte I would recommend charging them both up to a full charge and seeing if you experience these symptoms.
Highlighted
JUMP TO SOLUTION
How is this a solution?  I have the same issue.  I'm not sure that you were able to solve the issue just through some private message.
Highlighted
JUMP TO SOLUTION
How is this accepted as a solution???
This issue is certainly not solved or fixed!
Highlighted
JUMP TO SOLUTION
I am experiencing the same issue with my right Galaxy Buds+ ear piece. These are the new Buds+ that I purchased with my S20. I tried resetting the buds via the app but still same issue.
Highlighted
JUMP TO SOLUTION
I just bought the buds plus yesterday got home connected them to my phone noticed there was a software update notification but I couldn't install it becuase my right bud was completely drained dead. My left one was at 99% thr case was dead. So I charged everything took almost 3 hours. Didn't think anything of it. I finally got to use them. Then I put them away this morning I got up and went to use them and found that my keft bud was at 100. My right 85% I took out to adjust the bud thinking I didn't have it seated peoplerly looked at it had dropped from 85 to 83% so I adjusted them again and just a couple seconds ago I opened them to see if it was charged the light was green but when the indicator on my phone popped up it said it was at 80% Insteaf if charging my bud it is actually draining I have gone through this whole thread becuase it said solved thus issue has not been solved you click on jump to solution and it gives you instruction on  contacting you people so tell me exactly what it is that you have done to solve these peoples issue what do you plan on doing to solve mine?! Haven't even had these things for 24 hours is samsung in the practice of selling defective merchandise with the price tag that goes along with your  items maybe make sure that you can live ul to that price i could have bought 20 dollar i es thst would have performed better than this thanks!
Highlighted
JUMP TO SOLUTION
Im experiencing the same problem. I have sent it to samsung service centre and they wont replace it but they will repair it for free since its still under warranty. Mine is just 3months old... hopefully when i collect it i wont experience the same issue again.
