MJFrithjof
- Mute
‎05-09-2023 06:57 PM in
Galaxy Buds
The sound quality on my Galaxy Buds2 Pro has been quite odd. They sound good (not perfect, but good) in ANC or Ambient modes, but extremely tinny and lacking bass when in the normal mode. This problem did not used to occur, and only started after a recent earbud software update. Also, just make sure it was the earbuds themselves, I had tried to use my Buds Live as well, which seemed just fine. Could there be a solution to this, or should I wait for an update/return them?
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
Not applicable
- Mute
‎09-05-2023 03:41 AM in
Galaxy BudsAnyone found a solution? I also have a huge difference in sound quality when ANC or ambient more are turned off.
MJFrithjof
- Mute
‎09-05-2023 06:14 AM in
Galaxy Buds
Since my pair was under the warrenty, I requested a mail-in warrenty repair and had gotten them back in the correct quality.
- « Previous
- 1
- 2
- Next »
