Right bud has stopped connecting to lhone and charger case
(Topic created on: 10/8/20 9:39 AM)
usersZHcCvhQpl
Galaxy Buds
for some reason my right earbud stopped connected in did a reset cleaned looked on the internet nothing is working, the left one works fine. Please send me all recommednations.
SamsungMoon
Galaxy Buds
Hello!
After a reset has been done to no avail I would recommend unpairing and repairing your buds from the Wearables app and Bluetooth menu after clearing the cache and data from the Wearables App. You can do this by navigating to Settings>Apps>Wearables App>(Force Stop the app)>Storage, from here you can clear the cache and data.
If you are still experiencing this symptom after performing this, I would recommend getting your device evaluated by a technician to diagnose and repair your symptom. I would be happy to look into service options for you. Could you please provide me with the model and serial number for your Galaxy buds in a private message to do so? https://bit.ly/2SUXRar
Let me know if this helps!
JLA781
Cosmic Ray
Galaxy Buds
lol
@blah1027 wrote:
what is a ihone
userNaoQ9BikFn
Galaxy Buds
did you find any solution to this?
SamsungMoon
Galaxy Buds
Hello!
