Right earbud battery drain
(Topic created on: 1/21/21 12:45 PM)
user6nOvE3SFUe
Galaxy Buds
Hi,
   Recently the right earbud for my Galaxy earbuds keeps draining all the way, while the left earbud barely loses any power. Is this defective?
Patriot1776JG
Red Giant
Galaxy Buds
I would say so. but to be sure, I would make sure both are fully charged. If the right does, I would check the contact points to make sure they make a good connection. and then if it still drains to zero, I would contact Samsung care, if it is less then a year old they should be under warranty
SamsungRei
Galaxy Buds
Thanks for reaching out! If you have tried all of the steps @Patriot1776JG has provided, service would be recommended. Please send a private message with the model code and the serial number of the buds so I may look into this for you. http://bit.ly/2XERsky
