3pcssuits
Cosmic Ray
Right earbud volume super low
JUMP TO SOLUTION
Had these shortly after launch and having problems with the right earbud being significantly lower in volume then the left ear, making music while working out with both in my ear very annoying.
1 SOLUTION
Honored Contributor
Re: Right earbud volume super low
JUMP TO SOLUTION
If you have tried all of these steps with no success, then an exchange of the buds would be recommended. You can message us here with the full model code and serial number off of the case for more details: http://bit.ly/2igAXKH
465 REPLIES 465
JUMP TO SOLUTION
Have you completed all of the troubleshooting here: Low or poor audio quality on your Samsung earbuds and Phone displays volume limit reached message?
3pcssuits
Cosmic Ray
JUMP TO SOLUTION
Nope has not solved the issue, still right ear bud is about 75% lower then the left ear bud.
Honored Contributor
JUMP TO SOLUTION
userayn0CXAq6v
JUMP TO SOLUTION
tried what steps for goodness sakes. I cannot stand when a multibillion-dollar company creates a troubleshooting page, as a link that says jump to solution, then all of the solution says is when you tried all these steps and not list what the steps are. Now we are troubleshooting the troubleshooting. How frustrating.
userlY85wSi6gj
JUMP TO SOLUTION
My Galaxy buds have the same issue. None of those steps were able to fix it. Cant believe Samsung leaves this disturbing issue since iconx 2018.
Apehat02
JUMP TO SOLUTION
Same problem here. Tried all the steps. Reconnected, tried to update software, cleaned, charged... still low volume on right bud. It has come up a fee times, but goes right back down again in a fee minutes.
user0U5Ucf96VD
JUMP TO SOLUTION
How can I find out if mines are in warranty they do the same thing
userfwyWNb1tIo
Galaxy Buds- Right earbud Not Charging
JUMP TO SOLUTION
I recently got my galaxy buds and after the first time I connected I updated and the update froze. So I uninstalled galaxy wearable and I am unable to connect my buds. And now only the left earbud is charging. Any ideas?
Re: Galaxy Buds- Right earbud Not Charging
JUMP TO SOLUTION
Have you tried resetting your galaxy buds?
