userfwyWNb1tIo
Re: Galaxy Buds- Right earbud Not Charging
JUMP TO SOLUTION
How do you reset them?
JUMP TO SOLUTION
Give this link a try: https://www.samsung.com/us/support/troubleshooting/TSG01111287/
userfwyWNb1tIo
JUMP TO SOLUTION
I cant connect them to the galaxy wearable app becasue the bud isnt charged.  out of the box they connected and i updated them adn the update froze so i had to stop the app and they never connected again.
JUMP TO SOLUTION
Give this a try: Ensure the BT connection is disconnected from the phone’s settings & place the earbuds back into the cradle for 1 minute. Make sure the Galaxy Buds are charged for at least 15 minutes & re-pair to the phone
userfwyWNb1tIo
JUMP TO SOLUTION
Can they connect to the phone if only 1 bud is charged, because only my left bud charges till the charge light turns green. The right bud is always red.
JUMP TO SOLUTION
Are you using the original Samsung charger plugged into a wall outlet to charge the buds? Have you verified the charging contacts are clean, and the buds sit correctly in the cradle?
userfwyWNb1tIo
JUMP TO SOLUTION
Yes, yes and yes
JUMP TO SOLUTION
Will you please send a PM with the model code and serial number of the Buds? http://bit.ly/2Kq3B5F
userq9NBIOOKc0
JUMP TO SOLUTION
Any update? I'm having the same problem...
JUMP TO SOLUTION
@userq9NBIOOKc0 have you tried any of the troubleshooting mentioned previously in this thread?
