Fold 4 warm, slow charge, and fast battery drain.
(Topic created: 02-28-2024 06:00 AM)
Namrek
Galaxy Fold
After updating to newest security patch, phone now gets warm and the battery drains significantly faster and is slow to charge. I've tried restarting, dialing *#9900#, and adjusting some battery settings and no luck. Checked phone apps and all are updated.
Anyone else with this issue or ideas on how to correct it?
Samsung_Moderator
Galaxy Fold
Hello, We're sorry to hear about the trouble. Something to keep in mind too, when there's a big update, it may reset the battery learning patterns, that's why some may experience this after updates.  If it doesn't get better within a few days it may be an application that's causing the drain, Check out this link; https://www.samsung.com/us/support/troubleshooting/TSG01001388/
Regarding your device overheating, We recommend checking out the following troubleshooting steps: https://www.samsung.com/us/support/answer/ANS00076952/
If those troubleshooting steps are followed, and you still are having issues, we would recommend taking the device to a technician to perform diagnostics or a potential re-flash of your software. http://www.samsung.com/us/support/service
userxF8INcbRVb
Galaxy Fold
Mine lost access to bluetooth, wifi and hotspot. Also was draining my battery but I search up zfold4 in the community and found steps to reset the phone and it seems to have worked.
Samsung_Moderator
Galaxy Fold
