Samsung note 9 Samsung flow smart view
I have used Samsung flow for a while now and I can only get the smart view option to work once in a while. Either it won't load at all or it will say my wifi to unstable I currently have the eero pro 3 pack and one is right next to me. Anyone have any information that might help?
Red Giant
Re: Samsung note 9 Samsung flow smart view
what are the carrier, model number, and software build number from the settings > about phone?
what is the samsung flow version?
what are you connecting via samsung flow?
My carrier is Sprint phone model number Sm-n960U software build is M1AJQ.N960USQS1ARJ9  software version  N960USQS1ARJ9 Samsung flow Version 3.5.14 trying to use the smart view to mirror my screen. Via windows 10 pc with the Samsung flow from the windows store.
Red Giant
ok. let's delete the wifi in the saved wifi list and re connect and see if that will resolve it. also, try on different wifi and pc if possible to see if it could be the pc side.
With the new update I got the other day it looks to be working all the time right now. Thanks for the help
