userCTqJdoamD1
Battery wont charge
I just ran into this issues. My note 10+ is at the state where it cant charge and wont charge due to temperature being to low. I have owned Samsung and stuck with Samsung my whole life with no issues until this phone.
3 REPLIES 3
Samsung_SAzrEnQ
Re: Battery wont charge
I am having the same issue. Is Samsung addressing this issue? It started happening afterthe update
Badazznc
Cosmic Ray
Factory reset it
Thank you for reaching out. I would be happy to assist you further. Are you using the original charger that came with the device? Have you tried another Samsung charger? Are you able to charge your device wirelessly?
