Samsung_tgcngoA
So my galaxy note 4 phone drains very fast. I only have 2 hours on a 100% battery. How can i stop the drainage and have more battery life.
1 SOLUTION
Re: Battery
JUMP TO SOLUTION
You can try these tips to extend your battery life. https://www.samsung.com/us/support/answer/ANS00078987/
1 REPLY 1
Re: Battery
JUMP TO SOLUTION
