EyeBall
Display rotation issue
JUMP TO SOLUTION
Hi!
I have Note 4 phone with the latest update. When I play games like Clash of Clans and the battery gets to 25% a notification popups and rotate the screen in normal position, and the Dismiss button is missing. I have to plug the power cable to the phone to remove the notification. Is there any other way to remove and dismiss the popup window?
1 SOLUTION
Honored Contributor
Re: Display rotation issue
JUMP TO SOLUTION
Hey @userEGBiKVxUmt
This notification does seem to be a bit of an annoyance. When in the other rotation the dismiss is there, but for some reason isn't in landscape. While I don't have a fix for it, you aren't the first person to report it either. I'm looking into settings trying to figure out a way to either stop the notification or adjust it in some way. While it might take an update to fully fix, I want to thank you for reporting it so it can be looked into with more detail.  Smiley Happy
3 REPLIES 3
Honored Contributor
JUMP TO SOLUTION
Hey @userEGBiKVxUmt
EyeBall
JUMP TO SOLUTION
Thank you so much! Smiley Happy We are waiting for the fix
Blazingjesse408
I think you just slide the notification bar up
JUMP TO SOLUTION
