Eaternet connection for Note 10+
(Topic created: 04-28-2020 03:29 AM)
userUx1bXNs2ni
Galaxy Note Phones
Anynody tried using Samsun Note 10 + on eathernet?
Does it work? If yes, what adaptor did you use?
Thanks
mkkim
Comet
Galaxy Note Phones
Hello@userUx1bXNs2ni
i use Anker USE Type-C eathernet adaptor.
it works very well.
Hope this was helpful
mkkim
Comet
Galaxy Note Phones
it works very well.
userUx1bXNs2ni
Galaxy Note Phones
Thank you so much mkkim,
I did not find exact make but your suggestion gave me confidence to try ethernet to USB connector I had from apple.  I just needed to use Type C to USB female which came with Note to work.
Now I know ethernet is working on note 10, I have ordered a  Type C to ethernet  of another make for simpler solution.
Thanks again.
