Edge Bar missing on Note 10 Plus
(Topic created: 09-27-2020 02:13 PM)
TheRealThomas
Cosmic Ray
Galaxy Note Phones
Just purchased a Note 10 Plus.  There appear to be no Edge "options" other than lighting.  I loved the Edge panels on myNote 9, but they are not to be found.  It's odd, because I can see articles on the internet showing how to enable them but for me, there is no option to do so.  The more I use the 10 Plus the less I like it.  It seems Samsung removes more than they add with each iteration.  Sigh.
Does anyone have a fix?  Thanks in advance.
TheRealThomas
Cosmic Ray
Galaxy Note Phones
I finally figured it out.  For some reason, if "Easy mode" is enabled under "Display" settings it removes the "Edge panels" option under "Edge screen".   To get the "Edge panels" option to show up I had to set "Easy mode" (under "Display") to Off.
Thanks to everyone that tried to assist.
LongHiker
Galactic Samsung Care Ambassador
Galaxy Note Phones
The Note 10+ definitely has the Edge panel. If you aren't seeing it, I would recommend deleting the cache partition.
To do that:
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Bixby / Power key.
  3. Once the Android Recovery screen comes up, release the buttons.
  4. Use the Volume Down button until you are highlighting ‘Wipe cache partition.’
  5. Press the Power button to select ‘Wipe cache partition.’
  6. Use Volume Down to highlight Yes.
  7. Press the Power button to confirm the action to clear the cache.
  8. Wait for a second as the system wipes the cache.
  9. Press the Power button again to reboot the device. This will return the device to the normal interface.
TheRealThomas
Cosmic Ray
Galaxy Note Phones
Done.  Still no other option than lighting.  Figured I'd clear cache/data, so went to App Manager to look for Edge (showing all option), no Edge app to be found?!?
LongHiker
Galaxy Note Phones
Visit the Galaxy Store and search on "Edge". You can download "Edge screen" from there.
LauraRG
Comet
Galaxy Note Phones
Which options exactly are you looking for? my edge panel is on and if I go to search in settings and put in edge it shows the app just fine. also I have turned off the edge screen before by accident. couldn't figure out how to make it work again so did a reset and it was there again.
TheRealThomas
Cosmic Ray
Galaxy Note Phones
