Experiencing battery drain on Note 9 and 10 series
(Topic created: 10-07-2021 02:19 PM)
userxVKZW0Lgte
Galaxy Note Phones
Just wondering if anyone else is having the same issues with their notes 9 and 10 it seems that the battery life is draining faster this month that we've noticed.  Or maybe it's just Samsung Couldn't it be the update that's draining the battery?
Galaxy Note Phones
I would suggest performing a partition cache clear. I do this after every OS and security update to clean out the software bugs that sometimes come with these updates.
userxVKZW0Lgte
Galaxy Note Phones
Thank you, will try that.
SiouxziS8plus2
Galaxy Note Phones
My s8+ has the same problem. Nothing I've tried or that has been suggested has made any difference. I think the only hope is to replace it. I wish you better luck!
Gold_userL6
Cosmic Ray
Galaxy Note Phones
My Note 10+ was having a severe battery drain until I installed the Security Update.
I have noticed for a while that when it's time for Security updates and especially when you delay the updates the battery starts draining at a faster rate.
I do not believe this is anything new because it use to happen on my last phone as well.
