Galaxy Note 10 N970F USB-C cable
(Topic created: 07-22-2025 12:23 PM)
Galaxy Note Phones
Hello all,
I'm wanting to know what cable it is specifically for my N970F (Note 10) and it's charger.
Here's the link to the charger: https://www.samsung.com/mx/mobile-accessories/wall-charger-for-super-fast-charging-25w-black-ep-ta80...
I know it's a USB-C to USB-C, but I don't know the tech specs for it other than it needing to be 25 watts. What other thing do I need to know, tech specs wise? Amperage? What else?
I don't know if it has an official designation by Samsung, or if I can get it from a retailer like Amazon. Support by Samsung online tells me they don't have it in stock and therefore can't check the model number and hence I suppose the exact specifications.
So I'm looking for the model number of the USB-C to USB-C cable and the specifications for it so I can get it from either Samsung directly or a retailer.
Thank you in advance you guys.
GaryB82
Galactic Samsung Care Ambassador
Galaxy Note Phones
All you need to get is a standard USB-C to USB-C that will handle the wattage of the phone.  I always suggest getting Anker Cables since they are the best on the Market.  I've been using there cables for years and recommend this one below its a 2 pack 3ft and 6ft both will handle 25w's
https://www.anker.com/products/a8753?variant=40597771518102
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
Galaxy Note Phones
Galaxy Note Phones
Thanks – does the amperage and/or voltage of the cable matter in this sort of situation?
GaryB82
Galaxy Note Phones
No it won’t matter as long as you get a cable rated for 25w to match your charging brick it will be fine.
Galaxy Note Phones
Excellent. Thank you very much, Gary.
GaryB82
Galaxy Note Phones
Happy to help.  If you could click the 3 dot in the comment above that solved it and mark it as solved thanks
