Galaxy note 10+ low Battery temp
(Topic created: 11-11-2019 03:33 PM)
Samsung_LLXgNvO
Galaxy Note Phones
Need help fixing.Cant charge phone. Error message battery temperature to low. Seemed to come on after an update.
Anyone else having issue.
JUMP TO SOLUTION
userOxqKiH0Pa9
Galaxy Note Phones
I am currently having the same issue. My fone said battery temp too low shen i tried to charge it then in the evening said battery temp too low. I had my note 10 off the whole night and still the notificstion is on.
Samsung please assist South Africa
SamsungAdam
Galaxy Note Phones
@userOxqKiH0Pa9 Thanks for reaching out. This forum is for the support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
Samsung_l1QxhJ7
Galaxy Note Phones
Same problem here on my Note 10 Plus.  My battery says -4 degrees.  I sent it to Samsung, but they will not repair it because it has a cracked screen (that I said i would glady pay to have fixed).  They state out of warranty and wont fix at all now.  Been a loyal samsung client for the last 15 years.  They are in total denial that there is a problem, even after I told them to read these forums or google this problem.   I now have a $1,100 dollar paper weight!  Thanks Samsung!
userBzA9oFwFsH
Galaxy Note Phones
Same happened to me. I used the blow dryer to heat up my phone. After blow drying it for 2 minutes I charged it and it fully charged with no problem. Works good now.
userBzA9oFwFsH
Galaxy Note Phones
I had the same problem. I used a blow dryer to heat up my phone for 3 minutes and it fully charged with no problem. Haven't had that issue since.
Ranubis
Galaxy Note Phones
Have the same issue it just started today.  I charged the phone all night like I normally do and woke up to day used it as normal and went to hook it up at work at lunch as I normally do then boom Temp to low.... It is 74 Degrees in my office its in a case and been in my pocket.  I left the charger plugged up to it and went about my work and came to check it and the thing was burning hot felt like it was in the oven it lost all batter life went from 70% to 2% in 10 minutes.   I unplugged it and plugged it back in and even though the phone was extreamly hot it still said low battery temp warning.  The phone eventually died and now will not charge still says the same thing when you plug it in.  Contacted Samsung support and they were useless as usal.
userrCcuJIGwZa
Galaxy Note Phones
im having the same issue
SamsungRei
Galaxy Note Phones
A service repair is recommended.  Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
userGdYcpXLmJj
Galaxy Note Phones
This is my second note 10 with the same issue I usually carry it in my back pocket so if you bend it back the opposite way it  (plug in the charger and bend it back until it starts charging and you should be good ) should start working again and has to do with the charging pad connection when it disconnects it gives you that warning I've had my phone replaced and apparently this one's doing it too so I'm going to have to have it replaced again.
userFBvPduHfjS
Galaxy Note Phones
Recently I have been hearing a high pitched alarm noise and a warning that my battery temperature is too low when my Galaxy Note 10+ has been plugged in for charging. First it would happen about half way through charging, but now it is happening almost instantly when I plug my phone in to charge, sometimes two or three times in succession. And now my phone will not charge via the USB-c port. When it first happened I to use a little canned air to clean any debris from the charge port and I got a new charging cable.  I also updated the phone to android 10 to see if that would help. But tonight I could not charge at all through the USB-c port and ended up shutting the phone off and was able to charge it using a contactless charger which I borrowed.
I have seen several other posts regarding this issue, and it seems to go way back through the lines of galaxy phones. I saw posts as far back as the galaxy 7. Is this an inherent design flaw in Samsung phones?
Could my USB-C port be damaged?  Or is this an internal fault? Its shame as this phone might be a year old and I take quite good care of it. My Otterbox cover has a plug that keeps the charging port protected when not in use.
Anyone have any ideas of a fix or what is the inherent cause of this low temperature warning?
