Lgproduction
1 SOLUTION
Re: But i am from haïti
JUMP TO SOLUTION
Thanks for reaching out. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: http://www.samsung.com/visitcountry
8 REPLIES 8
Re: Help
JUMP TO SOLUTION
Can you give a bit more detail on the symptoms you are experiencing?
Lgproduction
Yes !i can!
JUMP TO SOLUTION
Yes !i can!
Samsung Care Ambassador
Can you force boot the device? If you can, I would do it....
JUMP TO SOLUTION
Can you force boot the device? If you can, I would do it. Than I would back up your data and factory reset it. Than attempt the update again.
Lgproduction
Ok !yes want to help me about it
JUMP TO SOLUTION
Lgproduction
But i am from haïti
JUMP TO SOLUTION
But i am from haïti
JUMP TO SOLUTION
What were you trying to update to?
JUMP TO SOLUTION
VBtoons
You should be able to restore your phone if your carrier...
JUMP TO SOLUTION
You should be able to restore your phone if your carrier has a recover software like Verizon does but has to to be used in conjunction with a PC and your USB-C cable.
