How can I work out if my samsung note 10 has water damage?
(Topic created on: 1/1/21 10:15 PM)
userKEzSUtlROC
Galaxy Note Phones
Over a year ago, I accidentally put my Samsung note 10 + in a washing and drying machine for an hour. It still works perfectly fine, but I was wondering if anyone knows how I can check to see if it is water damaged, or damaged from the heat? Thanks
jgparker
Galaxy Note Phones
I am amazed that it's still working! And if it's still working perfectly, my guess would be that it's not damaged. As for how to check to be sure though, you may want to call Samsung if no one else knows.
userKEzSUtlROC
Galaxy Note Phones
Yeah, I can't believe that it is still working. It was locked in a washing machine and I thought that it was going to be bent and broken, but when I took it out it didn't even have a scratch. When I took it out it just said that it was overheating and that it needed to cool down.
Galaxy Note Phones
If there had been water damage more than likely you would have received a "moisture in the charging port" warning message.
SHADOWGATE
Supernova
Galaxy Note Phones
either way the Manufacturers and carriers will know if you go to send it in. theres a litmus strip inside that changes from blue to pink when introduced to water but that's cool it survived the wash and dry process
LongHiker
Samsung Care Ambassador
Galaxy Note Phones
This happened over a year ago. Worrying about it now seems like a waste of effort.
userCvL7zFdO6H
Galaxy Note Phones
Which brand of washing machine.
