userqT8DB1bfC3
Cosmic Ray
Iris scanner LED
JUMP TO SOLUTION
The blue LED in the top left of my Galaxy Note 8 sometimes comes on or blinks.  Does it mean that the iris scanner is ready to scan?  I haven’t enabled the iris scanner so I don’t know why it comes on.
1 SOLUTION
Red Giant
Re: Iris scanner LED
JUMP TO SOLUTION
when iris scanner is on, it will blink red not blue. if u dont check received notifications, it will blink time to time to remind you that there are unread notifications.
It will light up LED indicator when the screen is off to show statuses of sound recording, unread notifications, and battery.
you can find this out from the settings > display > LED indicator
1 REPLY 1
Red Giant
JUMP TO SOLUTION
