Note 10+ Charger vs Note 8 Charger
(Topic created: 08-12-2020 01:58 PM)
userCEtCInKay1
Galaxy Note Phones
Does anyone know if the Note 8's Fast Charger can be used with the Note 10+?  Of course all of the newer model phones came with fast charger's, however the Note 10+ has a C cable / charger base.  Can the older model fast chargers be used as a secondary charger (i.e. office charger, extra home charger) when the charger that came with the phone isn't available?  Or are the two chargers different regarding the specs whereas though it won't charge as quickly and or possibly affect the Note 10+?  Thanks in advance for any responses, they would be greatly appreciated.
Respectfully,
Kevin
LongHiker
Samsung Care Ambassador
Galaxy Note Phones
Yes you can use the Note 8 charger with the Note 10+.
LongHiker
Galaxy Note Phones
userCEtCInKay1
Galaxy Note Phones
Thank you so much.
