Note 10 plus won't update firmware
(Topic created: 04-21-2024 11:27 PM)
userNdYYGyPLWW
Galaxy Note Phones
Any idea how to update the firmware? Doesn't work when I try updating
GaryB82
Galactic Samsung Care Ambassador
Galaxy Note Phones
What is the last update you received android ??? And model number
If it's SM-N975U or U1 the last update the phone received was
N975U1UES8HWG1
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
Galaxy Note Phones
N975U1UES8HWG1
ButtaBean_42
Neutron Star
Galaxy Note Phones
The Note 10 Series isn't eligible for anymore software or security updates
