SD Card Can't write
(Topic created: 01-05-2020 01:12 AM)
userK5eKeAKvzX
Galaxy S Phones
Hi, I have a "cant write to SD card" notification  permanent on my phone. This happened after the new 2 UI update, my 64G sd card works in other devices and was working fine before the update. Can we fix this in the next update please?
S10+
userXicRzIVMnt
Galaxy S Phones
Had the same problem and fixed it.
1. Unmount and backup on your PC/Laptop
2. Reinsert SD card to phone/tablet
3. From Settings navigate to Storage (on my device its located under Device care
4. Navigate to SD card and format
Bingo! Should work
Kolyei
Galaxy S Phones
You are probably going to need to get a new sd card. Formerly, they are pretty cheap online.
useri8eufQAH7O
Galaxy S Phones
Due to problem in your software, why would we change our SD card? 🤔🤔🤔🤔
This particular SD card is perfectly running in my another devices.
userDzmA0MZpCN
Galaxy S Phones
I woke up to this same exact message this morning on my S10. I updated to Android 10 the day before. Hard to believe that suddenly my SD card is going bad. Have never had that with SD card ever before.
userIhDXFYot5O
Galaxy S Phones
Same here. Updated to the new Android 10 update on my s10e 3 days ago and now my SD card is read only.
This is a bug not a bad sdcard
userzNvkmT5Cqr
Galaxy S Phones
Same message here on my S10. Just updated within the last 30 minutes, have never had any issues.
Come on Samsung.
userpfrS35KO8U
Galaxy S Phones
I have the same issue, just updated android on my s10 and now UI can't write to sd card messages popping up, any update?
userKh8cP12Tt3
Galaxy S Phones
Same problem with me, 128GB SAMSUNG SD Card no longer working after last update, formatted ... says successfull and then moments later says unsupporded card, and its a samsung in  a samsung phone .... fix the problem SAMSUNG !
userpZ11HdBz4m
Galaxy S Phones
Same problem for me with samsung 9+ after update Android 10  Smiley Sad
userNovYt9urKr
Galaxy S Phones
I only started getting this alert after right updated to android 10.... I wonder if they are trying to access my SD card well I'm asleep. I have auto update turned off on my phone.
