- Mute
03-02-2020 04:17 AM in
Galaxy Note PhonesI have a Note 9 and before I did the android 10 update the LED notification light would always blink for notifications whether in mute, silence, or ring. Now it's very sporadic with it most of the time not blinking when I get notifications. I've double checked and it is definitely on in the general settings and in the settings for the messages and phone apps. Is anyone else having this issue and/or is there fix?
Solved! Go to Solution.
- Mute
03-02-2020 03:01 PM in
Galaxy Note PhonesThank you. It appears with the Android 10 update Google has removed the triggers that would alert the LED notifications. However, there are 3rd party apps that would perform the same function. You can also try Edge Lighting. I sincerely apologize for the inconvenience.
- Mute
03-02-2020 12:58 PM in
Galaxy Note PhonesHave you verified the setting is turned on?
In addition, check the notification settings for the apps you are missing notifications for.
- Mute
03-02-2020 01:54 PM in
Galaxy Note PhonesYes it is on.
- Mute
