Note 9 charging issue.
(Topic created: 08-07-2021 01:14 PM)
Bigmusky8730
Galaxy Note Phones
A couple weeks ago my phone said there was water in the charge port and it was dry. So I cleaned it out with a q tip and it still said it was wet. So I had to shut it off and plug it in then restart it. This worked but, from then on none of my phone chargers worked. Sometimes the chargers aren't even recognized as being plugged in and others it says I'm plugged in when I'm not. The only way I'm able to charge is with my MacBook pro charger. I bought new cords and it tells me that I have to check connections because its not charging fast enough. I've tried blowing the port out with compressed air, I've done a soft reset (holding the power and volume down), I've wiped the cache partition, and I've put it in safe mode. Is there anything else I can do short of replacing the charge port in the phone?
1 Reply
usereb6NE03395
Galaxy Note Phones
8i0 OMG 898
