Note10+ Case help
(Topic created on: 1/12/20 9:49 PM)
userWN1EDZtm0Z
Galaxy Note Phones
I'm looking for what my local cellphone store calls a unicorn case (but shurly this has to exist...)
  1. Case /w a kickstand (also willing to toss a popsocket on if needed)
  2. Ability to mount easily in a car (the mounts I found so far are all light 'claw' mounts... the note 10 JUST fits in my current mount so with a case, it won't :( )
  3. Wireless charging must still work.
Thanks in advance.
LongHiker
Samsung Care Ambassador
Galaxy Note Phones
Spigen Tough Armor fits your criteria above.
Lewcifer
Cosmic Ray
Galaxy Note Phones
The Samsung Rugged Case for the Note10+ is a solid option.
Samsung_QPzp2hu
Galaxy Note Phones
I find what your local phone store calls it a unicorn case for the s 10 on Amazon
LongHiker
Galaxy Note Phones
userWN1EDZtm0Z
Galaxy Note Phones
@Lewcifer Looked at this one, sadly I didn't find a way to mount this guy in my car :(
@Samsung_QPzp2hu s10 not Note 10+.....
@LongHiker *insert face palm* this case is labelled as "Note 10 Plus" and not "Note 10+" that would 100% answer why I'm having so much trouble ugh.... thanks'
Samsung_c9zRKXl
Galaxy Note Phones
My galaxy Samsung 10 the battery drains extremely fast and always since day i bought it when i plug it in to charge it says device not charging slow not right charger
