Phone got dropped in water
(Topic created: 05-21-2021 04:23 AM)
ODarnItIGiveUp
Galaxy Note Phones
My Galaxy Note 10+ accidentally fell into my tub as I was taking a bath. It was in the water for just a second or two. Everything seems fine and working well. But at some point I did get a notification that water or moisture has gotten into the charge/USB port and that I should make sure the port is entirely dried before using it. It's been several hours since this happen and I think its dry now. But I was wondering is there a way I could check to be sure?
Adaboy
Supernova
Galaxy Note Phones
You could blow air into the port or go old school put it in a bowl of rice for a day to wick away moisture.
Adaboy
Supernova
Galaxy Note Phones
ODarnItIGiveUp
Galaxy Note Phones
Thanks 🙂
