Highlighted
Problems with my S Pen
So, I lost my original S Pen several weeks ago. I just recieved one I ordered a couple of days ago, but I cannot connect it. I works, I can write with it but there are certain actions that my new S Pen don't do. What the solucion could be ?
4 REPLIES 4
Highlighted
Re: Problems with my S Pen
If it's a Note 9/10/20, then try and insert the pen into the S Pen slot in the bottom of your device. If that doesn't work, try and go to your Bluetooth settings as the new S Pens have features working off Bluetooth, and connect to the pen from there.
Highlighted
Re: Re: Problems with my S Pen
Didn't work out. I mean, I can still use it. I'm just not able to use special function. Like the botton function and others... I can still write and do notes
Highlighted
@Ryz341 Have you tried any troubleshooting on the phone itself such as clearing the cache partition or a factory reset?
Highlighted
Yes. I have tried both. None of them worked. When I tried to use my pen's functions, my phone dont recognize the new pen I bought. It just gives me and error mensage and send me here, to Samsung Members
