- Mute
‎09-13-2019 07:36 AM (Last edited ‎03-18-2020 07:14 AM by knightsurgeon ) in
Galaxy Note PhonesWhat does the symbol in between the battery life and the LTE stand for???
Solved! Go to Solution.
- Mute
‎09-13-2019 07:39 AM (Last edited ‎03-18-2020 07:14 AM by knightsurgeon ) in
Galaxy Note PhonesThat indicates the Network Signal Strenght. If you're in a bad area it shows a few bars or none. If you're in a good coverage area, you should have full bars and good reception. Your internet speed is based in that. More lines tou have, faster internet you get
- Mute
![](/skins/images/4842330E96EDF2B66EA8F5D1E6119091/responsive_peak/images/icon_anonymous_message.png)
