Use Volume keys for media is not working on Note 9
(Topic created: 10-28-2019 06:03 PM)
userd8uWXD3aJn
Galaxy Note Phones
Hey guys,
I have a Note 9 and I have the setting to 'Use Volume keys for media' activated, but sometimes when I'm watching YouTube it adjusts the in-call volume. Any idea?
Charkatak
Supernova
Galaxy Note Phones
@userd8uWXD3aJn wrote:
Sorry forgot to mention that. Nope, no bluetooth accessories connected. This is weird right? I've tried that as well and it works for a few hours or so, then it resorts back to In-Call Volume.
@userd8uWXD3aJn
I know that this issue is not widespread as I have never seen this happen on my Galaxy devices.
- It is possible you may have an app that changes some volume settings or an option that optimizes settings such as: Go to settings>device care>battery>tap 3 dots on top right and tap settings.  In there you may find Optimize settings toggle(make sure it is off)
- Wipe cache partition:
1) Turn off the device.
2) Press and hold the Volume Up key and the Bixby key, then press and hold the Power key.
3) When the Android logo displays, release all three keys.
4) An 'Installing system update' message will show for some seconds before the Android system recovery menu options appear.
5) Press the Volume down key several times to highlight wipe cache partition.
6) Press Power key to select.
7) Press the Volume down key to highlight yes, them and press the Power key to select.
😎 When the wipe cache partition is complete, Reboot system now is highlighted.
9) Press the Power key to restart the device.
SamsungLarryK
Galaxy Note Phones
Does this occur if you deselect the option?
userd8uWXD3aJn
Galaxy Note Phones
If I deselect, the volume buttons then control the ringtone.
SamsungNik
Galaxy Note Phones
I know this kinda dumb, but any change if you reboot the phone? Who is your carrier if you don't mind me asking? I personally have the Note 9 through T-mobile and don't have the same issue.
userd8uWXD3aJn
Galaxy Note Phones
Yes, rebooting the phone does resolve the issue, but it happens roughly 2-3 times a day when I'm on an app that has audio (YouTube, Instagram, Facebook, etc). My carrier is Verizon. Do you think that has something to do it?
I think I've seen this issue in this message board before, just can't remember if it was resolved.
Charkatak
Supernova
Galaxy Note Phones
Hey guys,
@userd8uWXD3aJn
Do you have any bluetooth accessory connected to the phone?
Toggle "use volume keys for media" off, restart you device and then turn the option back on
userd8uWXD3aJn
Galaxy Note Phones
Charkatak
Supernova
Galaxy Note Phones
@userd8uWXD3aJn
userd8uWXD3aJn
Galaxy Note Phones
Ok I think I know what's causing it.
I have an app called Smart Life. It's for a wi-fi camera that I have installed in my home. It has a speaker and a mic on it. And when my volume is currently controlling media, it then switches to controlling in-call volume.
But, when I kill the app the volume buttons are still contrilling in-call volume. Now rebooting the phone does revert the volume buttons back to controlling media.
I've also tried to kill the app via Settings > Apps, and force stopping it. But that doesn't help. I'll still have to reboot the phone.
Any ideas?
Charkatak
Supernova
Galaxy Note Phones
@userd8uWXD3aJn
Killing the app, may not be a good test as the app might reload itself upon restart.  Don't know if it is a hassle to setup the app again after removing it.  If it isn't, then uninstall the app, reboot device, toggle "use volume keys.." switch to off and then back on justo to be on the safe side and use it for a day or two.
