Wireless Charger
(Topic created: 01-24-2021 06:23 AM)
userlDq9yKUfrt
Galaxy Note Phones
 I want to buy a fast charging wireless charger for my Samsung Note 10 plus  ... What type of charger is compatible with my phone? ... Is this charger suitable?
EP-N5100TBEGUS
Mari_K
Samsung Care Ambassador
Galaxy Note Phones
hello @userlDq9yKUfrt
the Note 10+ can support up to 15W wireless charging. So if you want the fastest wireless charging for your phone, get a wireless charger that is at least that.
*if I have helped you, please LIKE this post. If I have helped solve your problem, please mark this as a SOLUTION. Hope you have a great day!
TheGalaxy
Neutron Star
Galaxy Note Phones
I recommend not to
fast charging deteriorates your battery
gaudydregz
Galaxy Note Phones
bro the best one that I found to be used for best wireless charging would be to get the pocket juice charger Bank from Walmart it usually cost around 30 to 50 bucks but trust me dude it's worth it I have one and I use it for all three of my devices they usually charge up the devices about two times fully
Patriot1776JG
Supernova
Galaxy Note Phones
try Amazon
Mari_K
Galaxy Note Phones
