KuroSan
Halo
You will thank me for saving extra batteries for (Samsung phone)
I'm here with android P since beta version, lots of things happening. As far as I know there's still one thing that didn't change to save your battery, at the beginning you might feel weird but. When you get used to it, you can't even tell the difference.
Just turn on your blue light Filters.
Yeap just this step it will help saving more than you can imagine.
If this works for you. Let me know in the comments.
Long live Samsung Corp.
4 REPLIES 4
Samsung_23crsLB
Love the blue light filter. Discovered it when the s8+ ca...
Love the blue light filter. Discovered it when the s8+ came out, been using it since, even now with my s9+.
Samsung_AuVIaBa
Where do I find the blue lite filter
userTU2woyLZYo
For S10 you will need to go to settings and at the very t...
For S10 you will need to go to settings and at the very top of the screen in the search field type in blue light filter. Once you see that then all you have to do is tap on it to get to the settings.
KuroSan
Halo
How to turn on blue light filter? 2 ways. Easiest way :...
2 ways.
Easiest way :
On home screen
Swipe down to open your notification panel
And tap on blue light filter.
If you cant find it, go to button order and you know what to do next 😁
Little work :
Go to setting
Type blue light
And turn it on
