userjJvloKzAz9
Battery Fast Charge S7
JUMP TO SOLUTION
S7 Manual states Home Screen, Apps, Settings ....Tap Battery for Options.
The only screen I see after the above is one with "Device Maintenance" with ..
Battery, Storage, Memory.
Tapping this for Battery does not show "Battery Options"
Anyone know how to get to "Fast Charge" Option?
1 SOLUTION
FreshestDuggy
Re: Battery Fast Charge S7
JUMP TO SOLUTION
Go to device maintenance then battery, then hit the 3 dots button in the upper right corner
3 REPLIES 3
JUMP TO SOLUTION
Here is some information that may be helpful. Use Adaptive Fast Charging to Charge Devices
FreshestDuggy
JUMP TO SOLUTION
userjJvloKzAz9
JUMP TO SOLUTION
Plain and simple solution. I was able to discover this shortly before your reply.
Thank You.
