Battery does not charge after 1 year
(Topic created: 07-22-2021 10:15 AM)
Samsadbat
Galaxy S Phones
Battery not charging. Tried three different chargers. Hard believe Samsung makes a phone that only lasts 1 -2 years.
LongHiker
Samsung Care Ambassador
Galaxy S Phones
@Samsadbat what phone do you have?
Have you reached out to https://www.ubreakifix.com/ to get the battery replaced?
Samsadbat
Galaxy S Phones
Battery port connection problem. Thanks for the information.
Galaxy S Phones
Well I have bought my phone from August of 2019 and it seems as if the battery has only lost 20-30% of its actual capacity. Your battery may have became faulty after certain circumstances and environment changes, so I recommend getting a new phone.
MuscleDroid
Galaxy S Phones
Your charge port might need changed. Sometimes they get loose.
Samsadbat
Galaxy S Phones
Yes. I am hoping this is it. Thank you.
SelfProclaimedBest
Red Giant
Galaxy S Phones
Check your default USB selected action via the developer options sub settings menu and make sure its default is set to charging and not like say file transfer and try that.
Samsadbat
Galaxy S Phones
Interesting, a path i will look into. Thanks.
