Custom List Message Item |
I am a long time user of S series. I had S1, S3, S6 and S10. This year I need to buy a new phone, since the battery in S10 is dying. However, it... View Post
ImpossibleBox
You are much more civil in your frustrations than I am. Bothers me more knowing Samsung literally ma... View Post |
Hello Samsung,Please tell me why do you hate us so much???I have been your smartphone user since the days of S2, in the past the experience was... View Post |
Few weeks ago i went to the US for vacation (I'm from Nigeria) during that period i decided to get a samsung s10e from a certified samsung... View Post
SamsungRyder
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non... View Post |
Had an S22 on Xfinity Mobile. Tried to upgrade to a S24. When I activated it, it worked fine for about 5 minutes, then the message "Your eSIM... View Post
CarWhi-IT-Guy
Issue is resolved now. Xfinity servers were down last Thursday, and this issue started after that. I... View Post |
Just recently,, When in am app like FB or news I hit the back button and it opens my gallery. Can not find a fix for this View Post
Samsung_Moderator
Hello, welcome to the Community, and thanks for reaching out. This is indeed strange and not normal ... View Post |
The feature w an issue.. Keep screen on while viewing... This doesnt seem to be working again. Screen goes off while i qm... View Post
Popsicle20
Are you in a well lit area? The selfie camera needs to be able to see you for "Keep Screen on While ... View Post |
Here's what I believe needs to happen in order for the upcoming S25 Series to be worth buying/upgrading in 2025. 1.all variants... View Post
christopherharris91
Just wait until do the fold 6 ultra wishlist post. Samsung has rested on their lorals for 5 generati... View Post |
Does anyone know when and why the video call was removed from Samsung phones..?? I remember you had a icon on the phone but as time went on... View Post
Technotakusai
The functionality of the application is dependent on the recipient's device and mobile service provi... View Post |
https://us.community.samsung.com/t5/Galaxy-S24/Disability-advocate/td-p/2862551?src=ShareByUserCM View Post |
Trying to figure out how to change the language to English on my Samsung internet it's in Chinese View Post
Popsicle20
Go to Settings > General Management. I believe that the Language option at the top of the screen set... View Post |
When I'm done using my s10e I will usually close all recent apps, turn of screen and put phone in my pocket. When I open gallery to find a... View Post |
OLD PHONE - Galaxy S10 -One UI version 4.1-Android version 12. NEW PHONE - Galaxy S24 PLUS- One UI version 6.1-Android version 14. ... View Post
AbraxasGalaxyS24
Duly noted and I appreciate the help. I sent a DM with a Follow request. Did you get it? It may seem... View Post |
After struggling for a while with the S10+ freezing issue when using headphones, I finally found a solution. *#0*# settings, under the loop... View Post |
Ya know I've been using samnsung since 2012. And I must say they've been coming out with all sorts of new features and updates. One thing I... View Post
Popsicle20
Under Settings > Notifications there is an option to sort notifications by either priority or time. ... View Post |
I have a problem seeing my pictures as they do not look clear what can I do to get my pictures back to what they used to be. View Post |
User | Likes Count |
52 | |
35 | |
34 | |
23 | |
22 |
