userRYxDxrNuzv
Charging problem
JUMP TO SOLUTION
Hellow my phone has charging problem when i connect to charge it doesnt charge more than 15% and when i power it off and it charges up to 100% but whenever i try to switch it on it never goes on its on blinking samsung untill when the battery drains out
1 SOLUTION
userRYxDxrNuzv
Re: Charging problem
JUMP TO SOLUTION
Samsung s7 edge
3 REPLIES 3
JUMP TO SOLUTION
What type of device are you using?
userRYxDxrNuzv
JUMP TO SOLUTION
Samsung s7 edge
JUMP TO SOLUTION
Hey, give this a shot. It can show which apps are causing battery issues, viruses, malware or app crashes:
Device Care > App issue history
