Fast Wireless Charging Doesn't Always Work
(Topic created: 12-15-2020 05:18 PM)
userugigLSO0kk
Galaxy S Phones
hi, i just bought a 20w aftermarket wireless charger for my galaxy s9, and during testing, i saw if my fast wireless charging sometimes doesn't work, is that normal for a wireless charger?, thanks:)
St3v3C
Sun
Galaxy S Phones
it's normal for cheap after market chargers. sometimes the plug is under rated, sometimes the cord is not manufactured properly. what you're experiencing is a clear indicator that your charger is not up to the task and you should get something better
1 Reply
St3v3C
Sun
Galaxy S Phones
