userzYNBSz714s
Finger print problem
JUMP TO SOLUTION
Finger print sensor not working on my galaxy S8+. I have to restart my phone to get it working, however it stops working again after a short while.
1 SOLUTION
Honored Contributor
Re: Finger print problem
JUMP TO SOLUTION
Hello there, @userzYNBSz714s
Let's try some troubleshooting steps, just let us know how these go!
  1. Are all your Apps are up to date? You have 2 places that you need to look. Google Play store and Galaxy app store. Go to both and check My Apps. Make sure there is no app that needs updating.
  2. Is your phone OS up to date? Go to Settings, About phone and check for software update. Make sure you have the latest phone software.
  3. Clear phone cache. Instructions are here
  4. Clear Application cache and sometime Application data. Instructions are here
  5. Restart your phone in Safe mode. This is just to help you isolate the issue if it is caused by 3rd part apps. Instructions are here
If those don't help, we certainly want to assist you further with this matter. To better do that, can we have some added details about your specific device and this concern? Things that will help the most would be the exact model number and Baseband version (both under Settings>About Device) for your device as well as your carrier and when you started noticing this happen. Thanks!
10 REPLIES 10
Honored Contributor
JUMP TO SOLUTION
userNhJaKYgqVA
JUMP TO SOLUTION
I received a replacement phone in the mail today and neither the fingerprint scanner or iris scanner are working what could be the issue. I've updated to latest OS and all apps have been updated. I've tried to use in safe mode same issue. Did I receive a bad phone
JUMP TO SOLUTION
@userNhJaKYgqVA Could you be more specific about the troubles you're having? Are they not recognizing you fingerprint/iris? Are you not able to choose to use them? Are you receiving error messages?
userNhJaKYgqVA
JUMP TO SOLUTION
When I click to set up my finger prints it gives me an error message and when trying to setup my iris it gets to 50 percent and says iris not recognized
JUMP TO SOLUTION
@userNhJaKYgqVA; Give the troubleshooting steps below a try. Let us know if they are helpful.
Fingerprint Scanner Not Working:
Perform the following:
  • Settings
  • Apps
  • 3 Vertical Dots at the top right corner
  • Show System Apps
  • Fingerprint
  • Force Stop
  • Clear Cache
  • Clear Data
userNhJaKYgqVA
JUMP TO SOLUTION
Didn't work
JUMP TO SOLUTION
@userNhJaKYgqVAI am sorry to hear that. I would be happy to look into the issue further for you. Could you respond in a private message to http://bit.ly/2JH2rq2 with the following information?
First/Last Name
Phone Number
Email Address
Physical Address
Place of Purchase
Serial #
Model #
IMEI #
Honored Contributor
JUMP TO SOLUTION
Hey, @userzYNBSz714s. I just wanted to reach back out and see if those steps helped out! If not, please let the Community know so that they can look into different ideas to help further.
userzYNBSz714s
JUMP TO SOLUTION
Yes. The problem is resolved. Thank you
