Highlighted
Re: Galaxy S7 Edge Battery Drain after recent update
JUMP TO SOLUTION
how exactly do we "upgrade your software version to andriod security level for December 2017"?
Highlighted
JUMP TO SOLUTION
Yesterday i update my phone to January 2018 patch and after that my battery life is so good.
i got 6+ hours of screen on time now 😎
Exynos Variant Here !!
Highlighted
JUMP TO SOLUTION
Alright mate ✌
Highlighted
JUMP TO SOLUTION
Agree with you 👌
Highlighted
JUMP TO SOLUTION
if you are in a place where the reception is poor it drains the battery faster
Highlighted
JUMP TO SOLUTION
My phone is dropping out at 55% So disgusted moving back to sony. My galaxy had three batteries I swapped round to last a day. Not even got the option to do this. Dreadful con.
Highlighted
JUMP TO SOLUTION
Hello All,
I wanted to put up a solution that I have found after searching these forums.
Symptoms:
Screen on: Battery drains 1% every 30 seconds with screen on.
Screen off: Battery drains 1% every 3-4 minutes with screen off.
Solution:
I "recalibrated" the battery by keeping it on until the phone died and turned off on it's own. I turned the phone back on and let the battery die again within seconds. With the phone off, I charged the phone until it showed 100% on phone off screen. With the phone not charing I turned the phone back on. After doing this my battery indicator returned to normal and I was back to seeing normal drainage:
Screen on: Battery drains 1% every 4-5 minutes
Screen off: Battery drains 1% every 30-45 minutes.
Please Note:
When draining the phone down to dead, the phone showed a charge of 1% for 2.5 hours before finally dying. This lead me to believe the batteries charge level was way off and "recalibrating" it fixed it.
Give this a try to see if it works for you.
Highlighted
JUMP TO SOLUTION
After reading through 17 pages of the same issues - my S7 has the same happening after about 1 year.  My phone battery started draining very quickly (7am @ 100% - by 9am down to 75% while mostly on standby)
I did a little of what each of you have mentioned:
  • Disabled the Chrome app (using the Samsung Internet that came with phone)
  • went through apps and limited the background use to only select ones
  • stopped using wifi - (think this had most to do with it)
    • my phone only lost 4% last night over a 10 hour period
    • My phone used to get very hot - it hasn’t since performing the above (going on 24 hours)
  • Disabled Samsung+ and S Health.
  • Updated all apps through play store
Last evening at 11 pm (Battery at 95%)
Today at 9am (Battery at 90%)
Today at 11pm ( Battery at 59%) Didnt use it much as its sunday but it certainly a drastic change in standby time.
Not sure if all this makes sense as Im pretty much a novice but it seems that so far its working for me. Will update in about a week.
Highlighted
JUMP TO SOLUTION
I can't stop using WiFi lol
Highlighted
JUMP TO SOLUTION
Same here. My s7 battery has always been great! But since the new update I have to charge several times throughout the day. I'm not using my phone differently. Very irritating
