- Mute
- Email to a Friend
11-04-2016 08:52 AM in
Galaxy S PhonesBefore the recent update my phone e was getting through the day with no issues at all giving me 7am-10pm time fore first battery warning. After recent security update I noticed the battery use to die much more quicker, once I received first battery warning at 2pm other days on 4pm. I did not install any new apps, usage is as usual. Current version:
GQBSFXXU1 BPJE/
G935FOJV1 BPH4/
G935FXXU1 BPJE
I wander if anyone experiences the same issue? Is there a way to roll back to previouse version?
Thanks.
Solved! Go to Solution.
- « Previous
- Next »
- Mute
- Email to a Friend
08-21-2018 12:42 PM (Last edited 08-21-2018 12:47 PM ) in
Galaxy S PhonesI started to notice that my S7 used a lot more battery than usual some days ago (battery went down from about 95% to 50 % when I was asleep). And at the same time the phone got hot during charging. Before this occured I didn't do anything in the settings and have always used the original Samsung charger.
So I went through the battery and app settings and saw that the Always on display was the top user with 16 % since the last charging. It didn't sound like anything remarkable, but I turned off the Always on display. I went through the app list, and no app did really use any battery at all.
I also did restart the phone after that (which I haven't done in a while).
Well, as it turned out, the phone in now cold while charging, and doesn't use near as much battery while not used. I really don't know what solved it, but it's okay now.
I'm not an expert, but maybe this could be helpful for someone with the same issues.
Mike
- « Previous
- Next »
